Updated on 2025-09-11 GMT+08:00
Modifying an Application
Scenarios
After an application is created, you can modify its name or description by performing the following operations.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, select the application to be modified and click .
  5. Set parameters for modifying an application.
    Table 1 Parameters for modifying an application
    Parameter
    Description
    Example Value
    Application
    Customize an application name based on the naming rule.
    Test Application
    Description
    (Optional) Description of the application.
  6. Click OK.
    The application is modified.
Modifying a Sub-application
  1. Log in to COC.
  4. In the application list on the left, select the sub-application to be modified and click .
  5. Set parameters for modifying a sub-application.
    Table 2 Parameters for modifying an application
    Parameter
    Description
    Example Value
    Subapplication Name
    Customize the sub-application name based on the naming rule.
    Test sub-application
    Description
    (Optional) Description of a sub-application.
  6. Click OK.
    The sub-application is modified.
