Updated on 2025-09-11 GMT+08:00
Creating a Component
Scenarios
After creating an application or a sub-application by referring to Creating an Application or Creating a Sub-application respectively, perform the operations in this section to create a component under the application or sub-application.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, select the application for which you want to create a component, and click .
  5. Set parameters for creating a component.
    Table 1 Parameters for creating a component
    Parameter
    Description
    Example Value
    Component
    Customize the component name based on the naming rule.
    Test Component
  6. Click OK.
    The component is created.
