Updated on 2025-09-11 GMT+08:00
Viewing Capacity Details
Scenarios
Cloud Operations Center allows you to view the capacity details of resources associated with applications, sub-applications, components, or groups, and displays core resource data and rankings by resource type.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, select the application, sub-application, component, or group to be viewed. Click Capacity on the right of the page.
    Figure 1 Viewing capacity rankings
