Updated on 2025-09-11 GMT+08:00
Creating an OS Version Change Task
Scenarios
You can choose Resource O&M > Automatic O&M in the navigation pane. On the displayed page, click the OS Version Change card and create an OS version change task. After the task is created, a service ticket for upgrading the OS version is generated.
The OS version change feature is billed on a pay-per-use basis. You can create OS version change tasks as required. For details, see Billing Mode.
Creating an OS Change Task
  1. Log in to COC.
  2. In the navigation pane on the left, choose Resource O&M > Automated O&M.
  3. In the Advanced O&M module, click OS Version Change.
  4. Set the basic information.
    Figure 1 Configuring basic parameters
    Table 1 Basic information parameters
    Parameter
    Description
    Example Value
    IAM Agency
    (Mandatory) Scope of permissions that can be used on COC to execute jobs.
    ServiceAgencyForCOC
    Execution Description
    (Optional) Description of the job to be executed.
  5. Specify OS Type, Schema Type, and Target Version.
    • OS Type: Select the type of the OS you want to use for the target version. Currently, only Red Hat type is supported.
    • Architecture Type: Select the CPU architecture type you want to use in the target version.
    • Target Version: Select the target version.
      Figure 2 Configuring execution content
  6. Set the OS upgrade procedure.
    • The following 11 steps have been preset in the system: BusinessProcessingBeforeUpgrading User-defined, PreparationBeforeUpgrading, CheckBeforeUpgrading, BackupBeforeUpgrading, UpgradeOS, RebootOS, Sleep-20s, WaitingForOSReboot, SystemProcessingAfterUpgrading, BusinessProcessingAfterUpgrading User-defined, and BusinessVerificationAfterUpgrading User-defined.
    • BusinessProcessingBeforeUpgrading User-defined, BusinessProcessingAfterUpgrading User-defined, and BusinessVerificationAfterUpgrading User-defined support user-defined configurations. You can click Modify under each step to go to the Modify Parameter drawer on the right. You can select a customized script on the Basic Information tab page. On the Input tab page, modify the input parameters. Other steps do not support user-defined configuration.
      Figure 3 Custom parameters
  7. Click Add Instance and set instance information.
    Figure 4 Adding an instance
    Table 2 Instance parameters
    Parameter
    Description
    Example Value
    Selection Method
    Select an instance selection method. Select All is not enabled.
    • Manual Selection: Manually select an instance based on Enterprise Project, View Type, Resource Type, Region, and Target Instance.
    • Select All: Automatically select all instances based on Enterprise Project, View Type, Resource Type, Region, and Target Instance.
    Manual Selection
    Enterprise Project
    Select an enterprise project. You can select All.
    All
    View Type
    Select a view type.
    • CloudCMDB resources: Select an instance from the resource list.
    • CloudCMDB application groups: Select an instance from the application group list.
    CloudCMDB resources
    Resource Type
    Select a resource type. The default value is used and cannot be changed.
    ECS
    Region
    Select an execution region. The target DB instance cannot be selected across regions.
    CN North-Beijing4
    Target Instance
    Set filter criteria in the filter box and select the filtered instances manually or automatically.
    Select the required instance.
  8. Select a batch policy.
    • Automatic: The selected instances to be executed are automatically divided into multiple batches based on the preset rule.
    • Manual: You can manually create multiple batches and add instances to each batch as required.
    • No Batch: All instances will be executed in the same batch.
      Figure 5 Selecting a batch policy
  9. (Optional) Set global parameters.
    Click Modify to modify the global parameters related to the OS version change.
  10. Click OK, confirm the execution information, and click OK again.
  11. The OS version change service ticket page is displayed. You can perform the following operations:
    • Retry: If the service ticket status is abnormal, you can retry at the instance level and re-execute the current failed step.
    • Rollback: If the service ticket status is abnormal or complete, you can create an OS rollback task. After the task is created, an OS rollback service ticket is generated.
