Updated on 2025-09-17 GMT+08:00
Restarting an Incident
Scenarios
After an incident ticket is rejected, the incident applicant can edit and resubmit it.
  1. Log in to COC.
  2. In the navigation pane, choose Fault Management > Incidents.
  3. On the Pending tab page, select the target incident ticket and click its title.
  4. Click Re-opening in the upper right corner.
  5. Set parameters for changing the incident ticket.
    Table 1 Parameters for changing the incident ticket
    Parameter
    Description
    Incident
    Customize the incident name according to the naming rules.
    Description
    Describe the incident.
    Click Add File to upload incident-related attachments.
    A maximum of 10 files can be uploaded. The supported file types are JPG, PNG, DOCX, TXT, and PDF. The size of a single file cannot exceed 10 MB.
    Incident Level
    The options are P1, P2, P3, P4, and P5.
    NOTE:
    The incident levels are defined as follows:
    P1: Core service functions are unavailable, affecting all customers.
    P2: Core service functions are affected, affecting the core services of some customers.
    P3: An error is reported for non-core service functions, affecting some customer services.
    P4: Non-core service functions are faulty. The service latency increases, the performance deteriorates, and user experience decrease.
    P5: Non-core service exception occurs, which is customer consultation or request issue.
    Incident Category
    (Optional) Select an incident category from the drop-down list.
    Incident Ownership
    (Optional) Select the incident to which the ticket belongs from the drop-down list.
    • Alarm detection
    • Customer fault reporting
    • Proactive O&M
    • Other
    Region
    (Optional) The default value is N/A. Select the region where the event occurs from the drop-down list.
    Enterprise Project
    Select an enterprise project from the drop-down list.
    Fault Occurrence Time
    Enter the time when the fault occurs.
    Application
    Select the application affected by the incident from the drop-down list.
    Service Interrupted
    The options are Yes and No.
    Owner
    Select Shift or Individual.
    • Shift: Select a scenario and role from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
    • Individual: Select an owner. For details about how to configure an owner, see O&M Engineer Management.
  6. Click OK.
    The incident ticket is restarted. The incident status changes to unaccepted.
