Help Center/ Cloud Operations Center/ User Guide/ Faults/ Incident Management/ Creating an Improvement Ticket For An Incident
Updated on 2025-09-17 GMT+08:00
Scenarios
If there are product or O&M improvement items during the handling of an incident ticket, you can create an improvement ticket to follow up the handling.
Prerequisites
An improvement ticket can be created only after the incident is accepted.
  1. Log in to COC.
  2. In the navigation pane, choose Fault Management > Incidents.
  3. On the Pending tab page, select the target incident ticket and click its title.
  4. Click > Create Improvement Ticket or Create Improvement Ticket in the upper right corner.
  5. Set parameters.
    Table 1 Parameters for creating an improvement ticket
    Parameter
    Description
    Improvement Ticket
    Name of the improvement ticket.
    Application
    Select an application for which the improvement is performed from the drop-down list.
    Type
    Select an improvement type from the drop-down list.
    Improvement Owner
    Select an owner from the drop-down list.
    Improvement Acceptor
    Select an acceptance user from the drop-down list.
    Expected Completion
    Enter the expected completion time.
    You can select a day. The time cannot be earlier than the current day.
    Symptom
    Enter the symptom related to the incident.
    The value can contain a maximum of 1,000 characters.
    Improvement Ticket Closure Criteria
    Enter the improvement closure criteria.
  6. Click OK.
    The improvement ticket is created. On the incident details page, click Improvement Record to view the improvement ticket status and current owner. Click the improvement ticket name to go to the improvement management page and handle the improvement ticket.
