Updated on 2025-09-11 GMT+08:00
Overview
You can use collect, aggregate, and convert alarm data, and configure and manage alarm rules.
Core Features
  • Integrating alarm sources to generate raw alarms: This function can integrate multiple existing or third-party monitoring systems (such as Cloud Eye, AOM, and Prometheus) and collect scattered alarm data from services to generate raw alarms. You can enable or disable existing alarm sources or connect to third-party monitoring systems on the integration management page.
  • Generating aggregated alarms based on transfer rules: You can set alarm conversion rules to aggregate multiple raw alarms that match a specific rule into one alarm, which is called an aggregated alarm.
  • Handling aggregated alarms and restoring resources and applications: For aggregated alarms, you can convert them to incident tickets, or execute scripts and jobs to clear the alarms, and automatically notify the corresponding owner. Aggregated alarms reduce repeated alarms and avoid alarm storms, improving alarm handling efficiency.
  • Alarm rule management: This function helps you efficiently create and manage alarm rules. It provides the alarm rule configuration capability across accounts and regions, helping you improve the batch configuration efficiency. Currently, alarm rules can be configured only for Cloud Eye alarms.
Note that the initial aggregated alarm is the active alarm. After you handle the aggregated alarm, convert it to an incident, or clear the alarm, it will be moved to the historical alarm list.
Figure 1 Alarm management process
