Updated on 2025-09-11 GMT+08:00
Integrating a Monitoring System
Scenarios
In enterprise-grade IT O&M management, to ensure stable system running, multiple monitoring systems need to be integrated to comprehensively monitor the system status. However, integration configuration of each monitoring system requires independent integration procedure and each system needs to be integrated separately. As a result, the configuration process is complex and time-consuming. To simplify this process and improve O&M efficiency, COC introduces the following methods: The procedure for integrating each monitoring system into COC is provided in the integration description of each monitoring system. This standard and automated method can effectively reduce the configuration time and error rate, improving O&M efficiency.
COC supports different monitoring systems. The integration configuration of each monitoring system has an independent integration procedure. The following describes the integration procedure for some systems.
  1. Log in to COC.
  2. In the navigation pane, choose Fault Management > Data Sources.
  3. On the displayed page, locate the monitoring system you want to integrate into COC based on service requirements and click Integrate.
    The detailed system integration procedure is displayed. The integration procedure varies depending on the monitoring system.
  4. Click OK in the lower right corner.
    After the integration is confirmed, the status of the monitoring source changes to Enabled in the Integrated area on the Data Sources page.
  5. Complete monitoring system integration based on the integration procedure corresponding to the specific monitoring system.
A maximum of five monitoring systems can be integrated for customized integration. If the integration is incorrect, disable it and then delete it.
  1. Log in to COC.
  3. On the Data Sources page, in the To Be Integrated area, locate Other Monitoring Systems, and click Integrate.
    The detailed integration access procedure is displayed.
  4. Enter the short name and full name of the integrated system and click the button for confirming the integration in the lower right corner.
  5. Integrate a Huawei-built monitoring system.
    Currently, alarm management data can be ingested using the POST method. For details, see Reporting Alarms Using a Self-Built Monitoring System.
  6. Check whether the integration is successful.
    In the navigation pane on the left, choose Fault Management > Data Sources. In the Integrated area, check whether the status of the monitoring system you integrated is Enabled. If it is, the integration is successful.
Enabling and Disabling a Monitoring System
  1. Log in to COC.
  3. Slider on or off the Enable or Disable feature toggle of an integrated monitoring source.
    Enable or disable an integrated monitoring system as required.
Updating an Integration Sign
  1. Log in to COC.
  3. Click the monitoring system you want to update.
  4. Click on the right of the integration sign.
    The integration sign is updated.
