Creating and Managing Drill Plans
Scenarios
You can customize drill plans to systematically schedule failure modes for orderly drill tasks. When creating a drill plan, you need to specify the executor and execution time to form a standard task assignment basis. After the executor accepts the task, the system automatically generates a drill task. The task must be accurately associated with the preset failure mode and specific application region. This ensures that the drill scenario matches the actual service scenario and lays a foundation for subsequent drill execution and effect evaluation.
Precautions
You do not need to specify the enterprise project to which a drill plan belongs. The enterprise project must be the same as that associated with the failure mode.
Creating a Drill Plan
- Log in to COC.
- In the navigation tree on the left, choose Resilience Center > Chaos Drills.
- Click the Drill Plans tab.
- Click Create Drill Plan.
- Set parameters for creating a drill plan.
Figure 1 Creating a drill plan
Table 1 Parameters for creating a drill plan Parameter
Description
Failure Mode
The options are Use custom failure mode and Use preset failure mode.
Select a failure mode from the drop-down list box.
Executor
Select the user who performs the drill from the drop-down list.
Region
Select a region from the drop-down list.
Planned Drill Time
Set the end date of the drill.
The executor must complete the drill before the planned drill time.
Enterprise Project
This parameter is mandatory when Failure Mode Name is set to Use preset failure mode.
Select the enterprise project to which the drill belongs from the drop-down list.
- Click OK.
The drill plan is created.
Cancelling a Drill Plan
Only tickets in the pending state can be canceled. Only the creator can perform this operation.
- Log in to COC.
- Locate the drill plan you want to cancel, click More and choose Cancel in the Operation column.
- Click Cancel.
The drill plan is canceled.
Accepting a Drill Plan Ticket
- Log in to COC.
- Locate the drill plan you want to accept and click Accept in the Operation column.
The Create Drill Task page is displayed. For details, see Creating a Drill Task.
Feedback
Was this page helpful?
Chatbot
