Updated on 2025-09-11 GMT+08:00
Managing Deployment Architectures
Scenarios
You can create, modify, delete, view, copy, and export deployment architectures. You can use deployment architectures to draw and govern the architecture.
Creating a Deployment Architecture
  1. Log in to COC.
  2. In the navigation pane, choose Resilience Center > Architecture Design.
  3. Click Create Deployment Architecture.
  4. Configure the basic information.
    Figure 1 Configuring basic architecture information
    Table 1 Basic information parameters
    Architecture Name
    Name of the deployment architecture
    Description
    Description of the deployment architecture.
    Application
    Select the application to which the architecture belongs from the drop-down list.
    After an architecture is created, its associated applications cannot be modified.
    Enterprise Project
    Select the enterprise project to which the deployment architecture belongs from the drop-down list.
  5. Click OK.
    The deployment architecture is created.
Modifying a Deployment Architecture
  1. Log in to COC.
  3. Locate the target deployment architecture and click Modify in the Operation column.
  4. The parameters are the same as those for creating a deployment architecture. For details, see Table 1.
    Figure 2 Modifying a deployment architecture
  5. Click OK.
  6. The deployment architecture is modified.
Deleting a Deployment Architecture
  1. Log in to COC.
  3. Locate the target deployment architecture and click Delete in the Operation column.
  4. In the displayed dialog box, enter DELETE and click OK.
    The deployment architecture is deleted.
    Figure 3 Deleting a deployment architecture
Copying a Deployment Architecture
  1. Log in to COC.
  3. Locate the target deployment architecture and choose More > Delete in the Operation column.
    Figure 4 Copying a deployment architecture
    Figure 5 Configuring basic parameters
  5. Click OK.
    The deployment architecture is copied.
Exporting a Deployment Architecture
  1. Log in to COC.
  3. Locate the target deployment architecture and choose More > Export in the Operation column.
  4. Select the format to be exported.
    Figure 6 Exporting a deployment architecture
  5. Click OK.
    The deployment architecture is exported.
