Viewing the Repository List
Constraints
Item |
Description |
Permission constraint |
Only the tenant space owner or tenant administrator can view this page. |
You can view your repo list in three ways: Favorited, Joined, and Created. You can access the repository list in the following ways:
- On the CodeArts homepage, click Services > Repo under the navigation bar. The repository list page of CodeArts Repo is displayed, showing all your code repositories. Enter the name of any repository in the search box on the right of All repositories and the searched repository will be displayed.
- On the CodeArts homepage, click a project, and click Code > Repo in the navigation pane on the left to enter the repo list page. Enter the name of any repository in the search box on the right of All repositories and the searched repository will be displayed.
- If you have subscribed to the new CodeArts package or purchased any CodeArts Repo package, go to the CodeArts homepage, click your profile picture, and choose All Account Settings > Repo > Resource Usage. In the Repository List area, click a project to go to the repo list page, as shown in the following figure. Alternatively, you can click the storage usage and the number of repos in the upper left corner of the CodeArts Repo homepage to go to the Resource Usage page directly. If you are a tenant member, click
in the upper right corner to export the selected resource usage.
On the top navigation bar, choose Services > Repo. Choose Repos > Joined to view all repositories that you participate in. If you click in the row where a repository is located, you can favorite the repository. You can choose Repo > Favorited to view the repositories that you favorite. To view the repo you created, choose Repos > Created.
Feedback
Was this page helpful?
Chatbot
