Roles
In addition to the default roles admin and developer, you can use a ServiceComb engine account associated with the admin role to log in to the CSE console and perform operations based on service requirements.
Creating a Role
Creates a role and configures permission actions for the role in different service and configuration groups.
A maximum of 100 roles can be created.
- Log in to CSE.
- Choose Exclusive ServiceComb Engines.
- Click the target ServiceComb engine with security authentication enabled.
- Choose System Management. In the displayed Security Authentication dialog box, enter the name and password of the account associated with the admin role under the ServiceComb engine, and click OK.
- If you connect to the ServiceComb engine for the first time, enter the account name root and the password entered when Creating a ServiceComb Engine.
- For details about how to create an account, see Adding an Account.
- On the Roles tab page, click Create Role.
- Enter a role name. The role name cannot be changed once the role is created.
- Configure permissions.
- Set Permission Group.
- Set the service permissions.
- If you select All Services:
You can perform corresponding permission actions on all microservices of the ServiceComb engine.
- If you select Custom Service Groups, set the parameters according to Table 1.
- Set the configuration permissions.
- If you select All Configurations:
You can perform corresponding permission actions on all configurations of the ServiceComb engine.
- If you select Custom Configuration Groups, set the parameters according to Table 2.
- Set Action.
Configure the permission actions that can be performed by the role on the selected service group and configuration group based on service requirements. You can select multiple permission actions.
- All: Add, delete, modify, and query resources in the service group and configuration group.
- Add: Add resources to the service group and configuration group.
- Delete: Delete resources from the service group and configuration group.
If only Delete is selected, you cannot delete resources in the service group and configuration group. You must select View at the same time.
- Modify: Modify resources in the service group.
If only Modify is selected, you cannot modify resources in the service group and configuration group. You must select View at the same time.
- View: View resources in the service group and configuration group.
- Click Create.
Editing a Role
Modifies the permissions of the created role.
- Log in to CSE.
- On the Roles tab page, click Edit in the Operation column of the role to be edited.
- Modify Service Group, Configuration Group, and Action based on service requirements.
- Click Save.
Deleting a Role
Deletes a role that is no longer used.
- Deleted roles cannot be restored. Exercise caution when performing this operation.
- Before deleting a role, ensure that the role is not associated with any account. For details about how to cancel the association between a role and an account, see Editing an Account.
- Log in to CSE.
- On the Roles tab, click Delete in the Operation column of the role to be deleted. In the displayed dialog box, enter DELETE and click OK.
Viewing a Role
View the created roles of the ServiceComb engine based on the keyword of the role name.
- Log in to CSE.
next to the role to be viewed to expand the role details.
Service Group, Configuration Group, and Action of the role are displayed.
Feedback
Was this page helpful?
Chatbot
