Updated on 2025-09-09 GMT+08:00
Creating an Agent
Scenario
An agent is installed on a host and registered with CodeArts. It is used as a custom executor for code check and build tasks.
Agent pools support custom executors running the following OSs.
Table 1 Supported OSs for custom executors
OS
Version
CentOS
6.3, 6.5, 6.8, 6.9, 7.0, 7.1, 7.2, 7.3, 7.4, 7.5, 7.6, 8.0, 8.1, 8.2
Debian
8.2.0, 8.8.0, 9.0.0, 10.0.0
EulerOS
2.0, 2.2, 2.3, 2.5
Ubuntu
14.04, 16.04, 18.04, 20.04, 22.04
Windows
2012 R2, 2016, 2019, 7, 10
KylinOS
V10 SP1
Union TechOS
Server 20 (1050e)
OpenEuler
20.03
AlmaLinux
9.0
CentOS Stream
9
Mac OS
10.7 or later
Constraints
  • Install only one agent on a host. If multiple agents are installed, some of them may go offline during task execution.
  • Each agent executes only one task at a time.
  • To ensure successful installation, do not use temporary AK/SK.
  • For LINUX_DOCKER agent pools, disable Security-Enhanced Linux (SELinux) on their hosts to allow container startup.
    To disable the feature, perform the following steps:
    1. Log in to the target host and run the following command to open the configuration file:
      vi /etc/selinux/config
    2. Change SELINUX=enforcing to SELINUX=permissive or SELINUX=disabled.
    3. Save the changes.
    4. Run the following command to apply the changes.
      sudo setenforce 0
Prerequisites
  • An agent pool has been created. For details, see Creating an Agent Pool.
  • You must be an agent pool owner or administrator.
    If you create an agent as an IAM Identity Center user (a user created in the IAM Identity Center), use the AK/SK of an IAM user who has at least the administrator permission.
  • You have a host that meets the following requirements:
    • Specifications: 4 vCPUs | 8 GiB or above, disk space > 80 GiB
    • The host can access the public network.
  • CodeArts automatically installs Java, Git, and Docker on Linux hosts. You can also manually install them using the root account.
    For details about the installation methods, visit the official websites of Java, Git, and Docker.
  • If your host OS is Windows or macOS, install Java 8 and Git on the server using a system administrator account.
    If your host OS is Windows, install Java 8 (64-bit).
Creating an Agent
  1. Go to the CodeArts homepage.
    1. Log in to the CodeArts console, click , and select a region where you have enabled CodeArts.
    2. Click Go to Workspace.
      If your account uses the old billing mode (see Old Billing Modes), click Access Service.
  2. Click the username on the top navigation bar and choose All Account Settings.
  3. Choose Agent Management > Agent Pool.
  4. Find the target agent pool in the agent pool list and click its name to display the Agents tab.
  5. Click Create Agent.
    Figure 1 Creating an agent
  6. Configure parameters as required.
    Table 2 Creating an agent
    Parameter
    Description
    Auto Install JDK
    Available when the agent pool type is LINUX or LINUX_DOCKER, and enabled by default.
    This parameter is optional. Configure it as needed. Once enabled, CodeArts will automatically install JDK on the host.
    Auto Install Git
    This parameter is optional. Configure it as needed. Once enabled, CodeArts will automatically install Git on the host.
    Install Docker automatically
    Available when the agent pool type is LINUX or LINUX_DOCKER.
    Enabled by default when the agent pool type is LINUX_DOCKER.
    This parameter is optional. Configure it as needed. Once enabled, CodeArts will install Docker on the host and register and start the Docker service.
    Restart Without Re-registration
    Once enabled, the agent process will be automatically registered as a Linux system service. It will automatically resume and does not need to be created again when the host is restarted.
    AK
    Your access key ID (AK). For details, see Obtaining an AK/SK.
    SK
    Your secret access key (SK). For details, see Obtaining an AK/SK.
    Agent Name
    Agents with the same name cannot be installed on the same host.
    To facilitate management, it is recommended that the name be clear and associated with the agent IP address, such as 10.10.10.10-agent-01.
    Agent Workspace
    The working directory where the agent runs and executes tasks on the host. Different agents on the same host cannot use the same agent workspace.
    Example:
    • Linux: /opt/cloud/agent01
    • Windows: C:/opt/cloud/agent01
    • macOS: /opt/cloud/agent01
  7. Click the checkbox under Agent Workspace.
  8. Click Generate Command. The command for installing the agent is automatically generated in the command box.
  9. Click Copy Command.
  10. Log in to the host and run the copied installation command.
    • Linux host: Log in using the root account and then run the installation command.
    • Windows host: Log in as the administrator, open Git Bash, and then run the installation command.
    • macOS host: Log in using the root account and then run the installation command.
    If the following message is displayed, the installation is complete.
    Figure 2 Response returned after installation
  11. Return to the Agents page.
    Refresh the page after 10 to 30 seconds. If the status becomes Idle, the installation is successful.
    There are five agent statuses:
    • Running: The agent is running tasks. Agents in this state cannot be deleted.
    • Idle: The agent is connected but not running any task.
    • Disabled: The agent is connected but cannot run tasks.
    • Offline: The agent is disconnected. Log in to reconnect it, or delete it if it is no longer needed.
    • Deleting: The agent is being deleted.
Managing Agents
  5. Locate the target agent and perform the operations listed in the table below as needed.
    Table 3 Managing agents
    Operation
    Description
    Enabling/Disabling an agent
    • Click in the Operation column to disable the agent. After the agent is disabled, the Status column changes to Disabled.
    • Click in the Operation column to enable the agent. After the agent is enabled, the Status column changes to Idle.
    Deleting an agent
    WARNING:
    • The deletion cannot be undone. Exercise caution when performing this operation.
    • If you have enabled Restart Without Re-registration when creating an agent, the agent will be automatically re-registered once the host is restarted. To avoid this, log in to the host and run the uninstallation command before deleting the agent.
    • Deleting a single agent: On the Agents tab, click in the Operation column of the target agent to delete it.
    • Deleting multiple agents: On the Agents tab, select the target agents and click Batch Delete.
