Updated on 2025-09-09 GMT+08:00
Managing Alias Settings
Administrators can determine whether to allow IAM users to modify their aliases, and can also set aliases for them.
Constraints
This function is not available in the following regions:
  • AP-Singapore
  • LA-Sao Paulo1
  • LA-Mexico City2
Modifying Alias Settings
  1. Go to the CodeArts homepage.
    1. Log in to the CodeArts console, click , and select a region where you have enabled CodeArts.
    2. Click Go to Workspace.
      If your account uses the old billing mode (see Old Billing Modes), click Access Service.
  2. Click the username on the top navigation bar and choose All Account Settings.
  3. Go to the General > Global Settings page, and toggle on or off Disable Custom Alias as needed.
  4. Refresh the page, click the username , and click next to the username.
    • If is toggled on, the system prompts that editing is not allowed.
      Figure 1 Alias setting disabled
    • If is toggled off, the Set Alias dialog box is displayed.
      Figure 2 Setting an alias
