Overview
Scenario
Tags are the identifiers of DEW. Adding tag allows you to easily recognize and manage your data encryption resources.
Tags can be added during or after resource creation.
Tag Naming Rules
- Each tag consists of a key-value pair.
- A maximum of 20 tags can be added to a resource.
- For each resource, a tag key must be unique and can have only one tag value.
- A tag consists of a tag key and a tag value. The naming rules are listed in Table 1.
- Tags are key-value pairs, which are used to identify, classify, and search for vaults. Vault tags are used to filter and manage vaults only. A vault can have up to 10 tags.
If you have configured tag policies for DEW, add tags for keys and secrets based on the policies. If the tag does not comply with the policies, keys and secrets may fail to be created. Contact the administrator to learn more about tag policies.
Table 1 Tag parameters Parameter
Rules
Example
Tag key
- This parameter is mandatory.
- The tag key must be unique for the same custom key.
- 128 characters limit.
- The value cannot start or end with a space.
- The value cannot start with _sys_.
- The following character types are allowed:
- Chinese
- English
- Digits
- Space
- Special characters: _.:=+-@
cost
Tag value
- This parameter can be left empty.
- 255 characters limit.
- Chinese
- English
- Digits
- Space
100
Feedback
Was this page helpful?
Chatbot
