Help Center/ Edge Security/ User Guide/ Security Protection/ Protection Policy/ Address Group Management/ Modifying or Deleting a Blacklist or Whitelist IP Address Group
Updated on 2025-09-15 GMT+08:00
This topic describes how to modify or delete an IP address group.
Prerequisites
You have created an IP address group.
Constraints
  • An IP address or IP address range that has been added to an IP address group cannot be added to any other IP address group.
  • Only address groups not used by any rules can be deleted. Before you delete an address group that is being used by a blacklist or whitelist rule, remove the address group from the rule first.
Procedure
  1. Log in to the EdgeSec console.
  2. In the navigation pane on the left, choose Edge Security > Policies. On the Address Groups page that is displayed, click the Address Groups tab. The Address Groups tab page is displayed.
  3. In the address group list, view the address group information.
    Table 1 Parameter description
    Parameter
    Description
    Group Name
    Address group name you configured
    IP Address/Range
    IP addresses or IP address ranges added to the address group
    Remarks
    Supplementary information about the address group
  4. Modify or delete an IP address group.
    • Modify an address group.
      In the row containing the address group you want to modify, click Edit in the Operation column. In the Modify Address Group dialog box, change the group name or IP address/IP address range, and click Confirm.
    • Delete an address group.
      In the row containing the address group you want to delete, click Delete in the Operation column. In the displayed dialog box, click Confirm.
