Updated on 2025-09-19 GMT+08:00
Constraints
  • Do not run x2hce-ca in the runtime environment because additional resource packages are created during its installation. The x2hce-ca tool can only be installed and used in HCE and CentOS.
  • The x2hce-ca tool can scan only files in .jar, .py, .pyc, .bin, .sh, .rpm, or .ko format. RPM files must be written in C, C++, Java, or Python.
  • The x2hce-ca tool does not support rollback. If a task is interrupted unexpectedly, you can retry. The residual files in the /opt/x2hce-ca/ directory do not affect the use of the tool.
  • The x2hce-ca tool can run only in the system that meets the requirements in the table below.
    Table 1 Hardware requirements for running x2hce-ca
    Hardware Type
    Description
    Architecture
    x86_64, aarch64
    CPU
    Dual-core or higher
    Memory
    At least 8-GB available memory
    System disk/Root partition
    20 GB or above
