Updated on 2025-09-19 GMT+08:00
Evaluating Software Compatibility
Scanning Methods
The x2hce-ca tool can:
  • Scan a single application package or multiple application packages on the source OS.
  • Scan all application packages in a given directory or multiple directories on the source OS.
Procedure
  1. Log in and switch to root.
  2. Scan the application packages to check for compatibility.
    x2hce-ca scan <option> [-os_name Source OS name] [-target_os_name Target OS name]
    Run the following command to verify the default Java version:
    java -version
    • If Java 1.8.0 is installed on the target server, subsequent scanning is automatically performed.
    • If Java 1.8.0 is not installed on the target server, perform the following operations (which vary depending on the OS):
      • If the OS is HCE 2.0, the missing Java dependencies java-1.8.0-openjdk-devel, java-1.8.0-openjdk, and java-1.8.0-openjdk-headless will be installed automatically.
      • If the OS is not HCE 2.0, an error message will be displayed to remind you to install the missing Java dependencies. Run the following command to install the Java dependencies:
        yum -y install java-1.8.0-openjdk-devel
    • If Java of multiple versions is installed on the target server and the default version is not 1.8.0, run the following command and set it to 1.8.0:
      update-alternatives --config java
    <option> has the following settings:
    • Dir_Name/App_Name: scans a single application software package.
      The following uses x86_64 and aarch64 as examples:
      For example, if you want to scan the application package NetworkManager-1.18.8-1.el7.x86_64.rpm in the /mnt/ directory, run the following command:
      x2hce-ca scan /mnt/NetworkManager-1.18.8-1.el7.x86_64.rpm -os_name centos7.9 -target_os_name hce2.0
      For example, if you want to scan the application package NetworkManager-1.18.8-1.el7.aarch64.rpm in the /mnt/ directory, run the following command:
      x2hce-ca scan /mnt/NetworkManager-1.18.8-1.el7.aarch64.rpm -os_name EulerOSV2.0SP8arm -target_os_name hce2.0arm -arch aarch64
      The default value of -arch is x86_64.
    • Dir_Name1/App_Name1 Dir_Name2/App_Name2: scans multiple application software packages.
      The following uses x86_64 as an example:
      For example, if you want to scan the application software package grep-3.4-0.h3.r3.eulerosv2r9.x86_64.rpm in /opt/x2hce-ca/scan/ and the application software package groff-1.22.4-5.h1.eulerosv2r9.x86_64.rpm in /opt/x2hce-ca/scan/rpm/, run the following command:
      x2hce-ca scan /opt/x2hce-ca/scan/grep-3.4-0.h3.r3.eulerosv2r9.x86_64.rpm /opt/x2hce-ca/scan/rpm/groff-1.22.4-5.h1.eulerosv2r9.x86_64.rpm -os_name centos7.9 -target_os_name hce2.0
    • -b Dir_Name: scans all application packages in a single directory.
      For example, if you want to scan all application packages in directory1, run the following command:
      x2hce-ca scan -b directory1 -os_name centos7.9  -target_os_name hce2.0
    • -b Dir_Name1 Dir_Name2: scans all application packages in multiple directories.
      For example, if you want to scan all application packages in directory1 and directory2, run the following command:
      x2hce-ca scan -b directory1 directory2 -os_name centos7.9 -target_os_name hce2.0
      A single directory can contain a maximum of 750 files of up to 900 MB. Excessive software packages may cause tool failures.
    • -l rpm_Name: scans a piece of locally installed software.
      For example, to scan OpenSSL, run the following command:
      x2hce-ca scan -l openssl
    • -l rpm_Name1,rpm_Name2...: scans more than one piece of locally installed software.
      For example, to scan OpenSSH and OpenSSL, run the following command:
      x2hce-ca scan -l openssl,openssh
      -l is available for x2hce-ca only in CentOS.
    Table 1 Type
    Parameter
    Type
    Description
    -os_name
    String
    Source OS.
    This parameter is optional. The default value is centos7.9. For details about other parameters, see Overview of x2hce-ca.
    For example, if this parameter is set to centos8.2, CentOS 8.2 is selected as the source OS.
    -target_os_name
    String
    Target OS.
    The default value is hce2.0 for HCE 2.0. For other parameters, see Overview of x2hce-ca.
    For example, if this parameter is set to -target_os_name hce1.1, the target OS is Huawei Cloud EulerOS 1.1.
  3. Analyze the evaluation results.
    For example, after the x2hce-ca tool scans three RPM packages in the /tmp/x2hce-ca_test directory, it displays the following outputs.
    Figure 1 Scan result
    • Download the compatibility evaluation reports from the /opt/x2hce-ca/output/software/ directory.
      • If the software package is compatible with the target OS, the following message is displayed.
        Figure 2 Evaluation result for software package compatibility
        If the software package is not compatible with the target OS, the following message is displayed.
        Figure 3 Evaluation result for software package incompatibility
      • For details about the compatible dependency packages and APIs, see the .xlsx file with the same name as the software package.
        Figure 4 Dependency package compatibility and API compatibility
    • If application packages fail the check, view the Excel report in the /opt/x2hce-ca/output/software/ directory.
