Updated on 2025-09-19 GMT+08:00
Configuration File
This section describes each configuration item in the static acceleration configuration file and dynamic acceleration configuration file.
Static Acceleration Configuration File
The following figure shows the default configuration of static acceleration. You can customize a configuration file to optimize applications.
Figure 1 Example of default configuration for static acceleration
Table 1 Configuration information
Module
Description
binary
Binary file attributes. For details about the binary parameters, see Table 2.
parameter
A collection of user-defined parameters. A parameter set is generated based on this collection of parameters. At least one parameter must be defined.
You can run the llvm-bolt -h command to view all parameters.
include
Parameters that must be contained in the collection of user-defined parameters. Multiple parameters are allowed. The logical relationship between parameters is AND.
The key of the configuration item is the parameter name, and the value is specified, for example, frame-opt=none.
NOTE:
  • If the value cannot be specified or does not need to be specified, end the key with an equal sign (=), for example, frame-opt=.
  • If include and exclude contain the same parameter, exclude precedes include.
exclude
Parameters that do not need to be contained in the collection of user-defined parameters. Multiple parameters are allowed. The logical relationship between parameters is AND.
NOTE:
Table 2 binary parameters
Item
Value Type
Default Value
Description
binary_out_path
String
"/data/hce-wae-auto"
Defines the path for saving the binary file that is automatically generated.
binary_file_suffix
String
"blot.auto"
Defines the suffix of the binary file name that is automatically generated.
Example Static Acceleration Configuration File
[binary]
binary_out_path = "/data/llvm_auto"
binary_num_threshold = 1000
binary_file_suffix = "blot.auto"
[parameter]
parameters =
    --align-blocks              # Parameter prefix -- can be added.
    frame-opt                   # If you do not need to specify the value of a parameter in the collection of user-defined parameters, you do not need to end the key with an equal sign (=).
    align-functions=1            # If the value of a parameter in the collection of user-defined parameters is specified, the value of the parameter is 1 in all parameter combinations in the generated parameter set.
[include]
align-blocks=                   # If the parameter value cannot be specified, the configuration item is still ended with an equal sign (=).
[exclude]
frame-opt=none                  # The parameter and its value are specified. Parameter combinations whose parameter is frame-opt and value is none are filtered out from the generated parameter set.
indirect-call-promotion=         # The parameter is specified and is of the enumeration type. All parameter combinations whose parameter is frame-opt are filtered out from the generated parameter set.
Dynamic Acceleration Configuration File
The following figure shows the default configuration of dynamic acceleration. You can customize a configuration file to optimize applications.
Figure 2 Example of default configuration for dynamic acceleration
The modules in the configuration file are described as follows:
[mission]: parameters to be configured for the application.
[stop-strategy]: policy for stopping application optimization. Select one of the configurations.
Table 3 Configuration information
Module
Parameter
Description
[mission]
log-type
Indicates the way to collect logs during runtime. Only the instrumentation is supported
hotpatch-type
Indicates the way to hotpatch the optimized segments. Only mode1 (ptrace) is supported.
snapshot-path
Indicates the path for storing the optimized binary snapshot file.
origin-exe
Indicates the location of the original application. This parameter must be specified when logs are collected using instrumentation.
[stop-strategy]
run-times
Specifies how many times the application is optimized. Optimization stops when the number is reached. Currently, an application can be optimized only once.
period
Specifies the optimization period, in seconds. Optimization stops when the period expires. The value ranges from 1 to 600.
condition
Specifies the optimization condition. Optimization stops when this condition is met. This parameter is reserved.
