Help Center/ Huawei Cloud EulerOS/ User Guide/ Kernel Functions and Interfaces/ Multi-level Hybrid Scheduling of Kernel CPU cgroups
Updated on 2025-09-19 GMT+08:00
Background
In hybrid deployments, the Linux kernel scheduler assigns more scheduling opportunities to high-priority tasks and minimizes the impact of low-priority tasks on kernel scheduling. However, the two-level scheduling of online and offline services cannot meet this requirement.
To solve the problem, HCE 2.0 allows multi-level scheduling of kernel CPU cgroups and provides /sys/fs/cgroup/cpu/cpu.qos_level to extend the scheduling levels from two to five, allowing users to set the priority for each cgroup separately.
Constraints
cpu.qos_level is only available for cgroup-v1 and not for cgroup-v2.
Interface Description
Rules for cpu.qos_level to take effect:
  • Completely Fair Scheduler (CFS) selects task_group level by level from top to bottom. cpu.qos_level takes effect for child cgroups under the same parent cgroup.
  • When a child cgroup is created, it inherits the cpu.qos_level value of the parent cgroup by default, but the cpu.qos_level value can be reconfigured.
  • For QoS levels with the same priority, their resource competition complies with the policy of CFS.
  • On the same CPU, the tasks whose qos_level is less than 0 are always unconditionally preempted by tasks whose qos_level is greater than or equal to 0, regardless of their levels.
When a high-priority task is scheduled:
  • Online tasks can unconditionally preempt the CPU resources of offline tasks. During multi-core scheduling, online tasks can preferentially preempt the CPU resources of offline tasks on other cores. In the hyper-thread scenario, online tasks with priority 2 can evict offline tasks on the SMT.
  • When a task with a higher priority is woken up, the task is accelerated by time slicing and can immediately preempt the CPU resources of tasks with a lower priority to achieve a response at a lower latency (the minimum running time slice of CFS is ignored).
Table 1 Interface description
Interface
Description
cpu.qos_level
Specifies the CPU priorities of the cgroups. The value is an integer ranging from -2 to 2. The default value is 0.
  • cpu.qos_level >= 0
    Tasks in the cgroup are online tasks, which can unconditionally preempt offline tasks.
    A lower value indicates a lower priority (0 < 1 < 2). Online tasks with a higher priority can obtain more CPU resources than those with a lower priority.
  • cpu.qos_level < 0
    Tasks in the cgroup are offline tasks. The priority of -1 is higher than that of -2, meaning that tasks at level -1 have more CPU resources than tasks at level -2.
    If a parent cgroup is running offline services, child cgroups can only inherit the priority of the parent cgroup, and the priority cannot be changed.
Interface Configuration Example
Create cgroups A, B, and C, and configure the cpu.qos_level interface.
Figure 1 cgroup nodes A, B, and C
Table 2 Data planning
cgroup
cpu.qos_level Value
A
1
B
-2
C
2
  1. Create cgroup A and child cgroups B and C, and set their CPU scheduling priorities to 1, -2, and 2.
    Tasks in cgroups A and C can unconditionally preempt CPU resources of the tasks in cgroup B. cgroup C preferentially preempts CPU resources because the priority of cgroup C is higher than that of cgroup A.
    mkdir -p /sys/fs/cgroup/cpu/A
    echo 1 > /sys/fs/cgroup/cpu/A/cpu.qos_level
    mkdir -p /sys/fs/cgroup/cpu/A/B
    echo -2 > /sys/fs/cgroup/cpu/A/B/cpu.qos_level
    mkdir -p /sys/fs/cgroup/cpu/A/C
    echo 2 > /sys/fs/cgroup/cpu/A/C/cpu.qos_level
  2. Add the task1, task2, and task3 processes to cgroup B.
    The CPU scheduling priority of the task1, task2, and task3 processes is -2.
    echo $PID1 > /sys/fs/cgroup/cpu/A/B/tasks
    echo $PID2 > /sys/fs/cgroup/cpu/A/B/tasks
    echo $PID3 > /sys/fs/cgroup/cpu/A/B/tasks
  3. Add the task4 and task5 processes to cgroup C.
    The CPU scheduling priority of the task4 and task5 processes is 2.
    echo $PID4 > /sys/fs/cgroup/cpu/A/C/tasks
    echo $PID5 > /sys/fs/cgroup/cpu/A/C/tasks
  4. View the CPU scheduling priority and processes of cgroup B.
    [root@localhost cpu_qos]# cat /sys/fs/cgroup/cpu/A/B/cpu.qos_level
    -2
    [root@localhost boot]# cat /sys/fs/cgroup/cpu/A/B/tasks
    1879
    1880
    1881
  5. View the CPU scheduling priority and processes of cgroup C.
    [root@localhost cpu_qos]# cat /sys/fs/cgroup/cpu/A/C/cpu.qos_level
    2
    [root@localhost boot]# cat /sys/fs/cgroup/cpu/A/C/tasks
    1882
    1883
