Updated on 2025-09-19 GMT+08:00
About CVE
Common Vulnerabilities and Exposures (CVE) is a list of publicly disclosed vulnerabilities, each with a unique CVE serial number. To ensure HCE security, Huawei Cloud closely follows industry vulnerability warnings and fixes software vulnerabilities in a timely manner. You can view the security updates at HCE security advisories:
In accordance with the Common Vulnerability Scoring System (CVSS), HCE security updates are classified into the following levels:
  • Critical (high risk, mandatory)
  • Important (medium high risk, strongly recommended)
  • Moderate (medium risk, recommended)
  • Low (low risk, optional)
This section uses HCE 2.0 as an example. Before you install HCEOS security updates, deploy a remote repository, add security advisories, and configure clients to access the repository. For details, see Configuring an HCE Repository.
The command outputs vary depending on the HCE version.
