Updated on 2025-09-19 GMT+08:00
Overview
xGPU is a GPU virtualization and sharing service developed by Huawei Cloud. This service isolates GPU resources, ensuring service security and helping save costs by improving GPU resource utilization.
Architecture
xGPU uses the in-house kernel drivers to provide vGPUs for containers. This service can isolate the GPU memory and compute while delivering high performance, ensuring that GPU hardware are fully used for training and inference. You can run commands to easily configure vGPUs in a container.
Figure 1 xGPU architecture
Why Using xGPU
  • Lower cost
    As GPU technology develops, the price of a single GPU is rising though it can offer larger GPU compute. In some scenarios, an AI application does not require an entire GPU. xGPU enables multiple containers to share one GPU and isolates GPU resources to keep services securely isolated, improving GPU hardware utilization and reducing the resource cost.
  • Flexible resource allocation
    xGPU allows you to flexibly allocate physical GPU resources based on your service requirements.
    • You can allocate resources by GPU memory or compute as required.
      Figure 2 GPU resource allocation
    • You can isolate either of GPU memory or compute, and specify weights to allocate the GPU compute. The GPU compute is allocated at a granularity of 1%. It is recommended that the minimum GPU compute be greater than or equal to 4%.
  • Robust compatibility
    xGPU is compatible with open source container technologies such as Docker, Containerd, and Kubernetes.
  • Easy of use
    You do not need to recompile your AI applications and replace the Compute Unified Device Architecture (CUDA) library when your services are running.
