Line Chart
A line chart is used to analyze the data change trend in a certain period, which is reflected in the following aspects:
- Increment or decrement
- Increase/Decrease rate
- Regularity of increase/decrease (such as periodic change)
- Peak and valley values
Therefore, the line chart is the best choice for analyzing the data change trend over time. In addition, you can draw multiple lines to analyze the change trend of multiple groups of data in the same period, and then analyze the interaction and impact between data (such as in direct or inverse proportion).
Checking Line Charts
- Log in to the LTS console.
- On the Log Management page, select the target log group and log stream. The log stream details page is displayed.
- Click the Log Analysis tab.
- Enter a query and analysis statement by referring to Using SQL Analysis Syntax, set the time range, and click Search.
- Click
to display the queried data in a line chart. Set parameters in the General Settings right pane by referring to Table 1.
Figure 1 Line chartTable 1 Line chart parameters Type
Parameter
Description
Standard
Format
Select K,Mil,Bil, 1,000,000, or Byte,KB,MB from the drop-down list to specify the format of the Y axis.
Unit
Customize the unit of the Y axis.
Decimal Places
Sets the number of decimal places to be displayed.
Title Font Size
Sets the font size of the chart title.
Query/Analysis
X Axis
Numeric or string data is supported.
Y Axis
Numeric or string data is supported. You can select multiple data records.
Dimension
Select a value from the drop-down list. Generally, it is an ordinal variable.
Compare Trends
This function can be enabled when the X axis shows time data and Dimension is not specified.
After this function is enabled, set Comparison to a duration less than or equal to 24 hours. After the setting is complete, compare the data of the current time with the object time data.
Legend
Hide Legend
After this function is enabled, you can hide the legend and comparison results.
Legend Position
Select Top or Right.
Comparison Value
Indicates whether to display the maximum value, minimum value, average value, and sum value. You can select multiple options.
Graphics
Line Shape
Line type. Select Straight or Curved.
Line Width
Width of a polyline.
Show Data Markers
Whether to display the connection points.
Top Margin
Specifies the distance between the axis and the upper boundary of the graph.
Bottom Margin
Specifies the distance between the axis and the lower boundary of the graph.
Left Margin
Specifies the distance between the axis and the left boundary of the graph.
Right Margin
Specifies the distance between the axis and the right boundary of the graph.
Tooltip
Sort By
Dialog box configuration. When multiple Y-axis data records are selected, they can be sorted and displayed.
X Axis
Show
After this function is enabled, data on the X axis is displayed.
X Axis Title
Title of the X axis.
Y Axis
Show
After this function is enabled, the Y axis data is displayed.
Y Axis Title
Title of the Y axis.
Position
Position of the Y axis. Select Left or Right.
Feedback
Was this page helpful?
Chatbot
