Updated on 2025-09-07 GMT+08:00
Table
Table charts are one of the most common data display types and the most basic method for organizing and sorting data. By sorting data, you can quickly reference and analyze the data. By default, the data obtained through the query and analysis syntax is displayed in a table chart.
Checking Tables
  1. Log in to the LTS console.
  2. On the Log Management page, select the target log group and log stream. The log stream details page is displayed.
  3. Click the Log Analysis tab.
  4. Enter a query and analysis statement by referring to Using SQL Analysis Syntax, set the time range, and click Search.
  5. By default, the query results are displayed in a table below the log. Set parameters in the General Settings right pane by referring to Table 1.
    Table 1 Table parameters
    Type
    Parameter
    Description
    Standard
    Format
    Displays the table chart data in the specified format.
    Unit
    Specifies the unit of the data in the customized table chart.
    Decimal Places
    Sets the number of decimal places to be displayed.
    Title Font Size
    Sets the font size of the chart title.
    Query/Analysis
    Hidden Fields
    Select a target field to hide it in the table chart.
    Table
    Records per Page
    Number of data records displayed on each page.
    Display Total
    Displays the total number of entries in the table.
    Column
    Alignment
    Alignment mode of table data. The options are left alignment, right alignment, and center alignment.
    Filtering
    After this function is enabled, you can search for data in the table column.
    Sorting
    After this function is enabled, you can sort data in the table.
    Font Size
    Size of the table font. The value ranges from 12 px to 24 px.
