Number Chart
A number chart is usually used to represent a single data point or key metric. It can better display the relative size of information and data of the same type. The number chart is ideal for displaying key information and data that needs to be highlighted. It allows users to quickly and intuitively understand data trends and key metrics.
Checking Number Charts
- Log in to the LTS console.
- On the Log Management page, select the target log group and log stream. The log stream details page is displayed.
- Click the Log Analysis tab.
- Enter a query and analysis statement by referring to Using SQL Analysis Syntax, set the time range, and click Search.
- Click
to display the queried data in a number chart. Set parameters in the General Settings right pane by referring to Table 1.
Figure 1 Number chartTable 1 Number chart parameters Type
Parameter
Description
Query/Analysis
Data Column
Numeric or string data is supported.
Comparison Data
Select a field to compare. The value of the field is displayed in the chart.
Main Items
Title Font Size
Sets the font size of the chart title.
Format
Displays data in the specified format.
Data Text Size
Font size of the displayed value. The value ranges from 12 px to 80 px.
Data Unit
Unit of the displayed value.
Unit Text Size
Font size of the displayed value unit. The value ranges from 12 px to 50 px.
Decimal Places
Sets the number of decimal places to be displayed.
Add Comparison Data
After this function is enabled, the value of the field to compare is displayed.
Comparison Formatting
Displays the data to compare in the specified format.
Comparison Data Text Size
Font size of the value to compare. The value ranges from 12 px to 50 px.
Comparison Data Unit
Unit to compare.
Comparison Unit Text Size
Font size of the value unit to compare. The value ranges from 12 px to 50 px.
Description
Description of the displayed value and comparison trend. The description is displayed below the value.
Background
Background
Background color of a chart, which can be dark or light.
Feedback
Was this page helpful?
Chatbot
