Updated on 2025-02-25 GMT+08:00
Resource Formation Service (RFS)
The Organizations service provides Service Control Policies (SCPs) to set access control policies.
SCPs do not actually grant any permissions to a principal. They only set the permissions boundary for the principal. When SCPs are attached to a member account or an organizational unit (OU), they do not directly grant permissions to that member account or OU. Instead, the SCPs just determine what permissions are available for that member account or the member accounts under that OU.
This section describes the elements used by Organizations SCPs. The elements include actions, resources, and conditions.
For details about how to use these elements to create a custom SCP, see Creating an SCP.
Actions
Actions are specific operations that are allowed or denied in an SCP.
  • The Access Level column describes how the action is classified (List, Read, or Write). This classification helps you understand the level of access that an action grants when you use it in an SCP.
  • The Resource Type column indicates whether the action supports resource-level permissions.
    • You can use a wildcard (*) to indicate all resource types. If this column is empty (-), the action does not support resource-level permissions, and you must specify all resources ("*") in your SCP statements.
    • If this column includes a resource type, you must specify the URN in the Resource element of your statements.
    • Required resources are marked with asterisks (*) in the table. If you specify a resource in a statement using this action, then it must be of this type.
    For details about the resource types defined by Resource Formation Service (RFS), see Resources.
  • The Condition Key column contains keys that you can specify in the Condition element of an SCP statement.
    • If the Resource Type column has values for an action, the condition key takes effect only for the listed resource types.
    • If the Resource Type column is empty (-) for an action, the condition key takes effect for all resources that action supports.
    • If the Condition Key column is empty (-) for an action, the action does not support any condition keys.
    For details about the condition keys defined by Resource Formation Service (RFS), see Conditions.
The following table lists the actions that you can define in SCP statements for Resource Formation Service (RFS).
Table 1 Actions supported by Resource Formation Service (RFS)
Action
Description
Access Level
Resource Type (*: required)
Condition Key
rf:privateTemplate:list
Grants permission to obtain private template list of project.
list
privateTemplate *
rf:privateTemplate:create
Grants permission to create a private template.
write
privateTemplate *
rf:privateTemplate:delete
Grants permission to delete a private template.
write
privateTemplate *
rf:privateTemplate:showMetadata
Grants permission to display the details of private template.
read
privateTemplate *
rf:privateTemplate:updateMetadata
Grants permission to update the metadata of private template.
write
privateTemplate *
rf:privateTemplate:listVersions
Grants permission to display all version details of private template.
list
privateTemplate *
rf:privateTemplate:createVersion
Grants permission to create a private template version.
write
privateTemplate *
rf:privateTemplate:showVersionContent
Grants permission to obtain the content of private template version.
read
privateTemplate *
rf:privateTemplate:deleteVersion
Grants permission to delete a private template version.
write
privateTemplate *
rf:privateTemplate:showVersionMetadata
Grants permission to get the metadata of private template version.
read
privateTemplate *
rf:stack:create
Grants permission to create a stack.
write
stack *
rf:stack:deploy
Grants permission to deploy a stack.
write
stack *
rf:stack:list
Grants permission to list all stacks.
list
stack *
rf:stack:getMetadata
Grants permission to get the metadata of a stack.
read
stack *
rf:stack:delete
Grants permission to delete a stack.
write
stack *
rf:stack:getTemplate
Grants permission to get the template of a stack.
read
stack *
rf:stack:listEvents
Grants permission to list deployment events of a stack.
list
stack *
rf:stack:listResources
Grants permission to list all resources of a stack.
list
stack *
rf:stack:listOutputs
Grants permission to list all outputs of a stack.
list
stack *
rf:stack:createExecutionPlan
Grants permission to create an execution plan.
write
stack *
rf:stack:getExecutionPlanMetadata
Grants permission to get the metadata of an execution plan.
read
stack *
Grants permission to get an execution plan.
read
stack *
rf:stack:applyExecutionPlan
Grants permission to apply an execution plan.
write
stack *
rf:stack:listExecutionPlans
Grants permission to list all execution plans.
list
stack *
rf:stack:deleteExecutionPlan
Grants permission to delete an execution plan.
write
stack *
rf:stack:continueRollback
Grants permission to continue rolling back the stack.
write
stack *
rf:stack:continueDeploy
Grants permission to continue to deploy the stack.
write
stack *
rf:stack:estimateExecutionPlanPrice
Grants permission to estimate the price of an execution plan.
read
stack *
rf:stack:update
Grants permission to update stack properties.
write
stack *
rf:stackSet:create
Grants permission to create a stack set.
write
stackSet *
rf:stackSet:list
Grants permission to list all stack sets.
list
stackSet *
rf:stackSet:showTemplate
Grants permission to show the template of a stack set.
read
stackSet *
rf:stackSet:showMetadata
Grants permission to show the metadata of a stack set.
read
stackSet *
rf:stackSet:deploy
Grants permission to deploy a stack set.
write
stackSet *
rf:stackSet:delete
Grants permission to delete a stack set.
write
stackSet *
rf:stackSet:update
Grants permission to update stack set properties.
write
stackSet *
rf:stackSet:listStackInstances
Grants permission to list all stack instances.
list
stackSet *
rf:stackSet:createStackInstances
Grants permission to create stack instances.
write
stackSet *
rf:stackSet:deleteStackInstances
Grants permission to delete stack instances.
write
stackSet *
rf:stackSet:showOperationMetadata
Grants permission to show the metadata of an stack set operation.
read
stackSet *
rf:stackSet:listOperations
Grants permission to list all stack set operations.
list
stackSet *
Each API of Resource Formation Service (RFS) usually supports one or more actions. Table 2 lists the supported actions and dependencies.
Table 2 Actions and dependencies supported by Resource Formation Service (RFS) APIs
API
Action
Dependencies
GET /v1/{project_id}/templates
POST /v1/{project_id}/templates
DELETE /v1/{project_id}/templates/{template_name}
GET /v1/{project_id}/templates/{template_name}/metadata
PATCH /v1/{project_id}/templates/{template_name}/metadata
GET /v1/{project_id}/templates/{template_name}/versions
POST /v1/{project_id}/templates/{template_name}/versions
GET /v1/{project_id}/templates/{template_name}/versions/{version_id}
DELETE /v1/{project_id}/templates/{template_name}/versions/{version_id}
GET /v1/{project_id}/templates/{template_name}/versions/{version_id}/metadata
POST /v1/{project_id}/stacks
rf:stack:create
  • kms:cmk:decryptDataKey
  • iam:agencies:pass
POST /v1/{project_id}/stacks/{stack_name}/deployments
rf:stack:deploy
GET /v1/{project_id}/stacks
rf:stack:list
GET /v1/{project_id}/stacks/{stack_name}/metadata
DELETE /v1/{project_id}/stacks/{stack_name}
rf:stack:delete
GET /v1/{project_id}/stacks/{stack_name}/templates
GET /v1/{project_id}/stacks/{stack_name}/events
rf:stack:listEvents
GET /v1/{project_id}/stacks/{stack_name}/resources
GET /v1/{project_id}/stacks/{stack_name}/outputs
POST /v1/{project_id}/stacks/{stack_name}/execution-plans
GET /v1/{project_id}/stacks/{stack_name}/execution-plans/{execution_plan_name}/metadata
POST /v1/{project_id}/stacks/{stack_name}/execution-plans/{execution_plan_name}
DELETE /v1/{project_id}/stacks/{stack_name}/execution-plans/{execution_plan_name}
POST /v1/{project_id}/stacks/{stack_name}/rollbacks
POST /v1/{project_id}/stacks/{stack_name}/continuations
GET /v1/{project_id}/stacks/{stack_name}/execution-plans/{execution_plan_name}/prices
bss:discount:view
PATCH /v1/{project_id}/stacks/{stack_name}
rf:stack:update
iam:agencies:pass
POST /v1/stack-sets
rf:stackSet:create
iam:agencies:pass
GET /v1/stack-sets
rf:stackSet:list
GET /v1/stack-sets/{stack_set_name}/templates
GET /v1/stack-sets/{stack_set_name}/metadata
POST /v1/stack-sets/{stack_set_name}/deployments
rf:stackSet:deploy
DELETE /v1/stack-sets/{stack_set_name}
rf:stackSet:delete
PATCH /v1/stack-sets/{stack_set_name}
rf:stackSet:update
iam:agencies:pass
GET /v1/stack-sets/{stack_set_name}/stack-instances
GET /v1/stack-sets/{stack_set_name}/operations/{stack_set_operation_id}/metadata
Resources
A resource type indicates the resources that an SCP applies to. If you specify a resource type for any action in Table 3, the resource URN must be specified in the SCP statements using that action, and the SCP applies only to resources of this type. If no resource type is specified, the Resource element is marked with an asterisk (*) and the SCP applies to all resources. You can also set condition keys in an SCP to define resource types.
The following table lists the resource types that you can define in SCP statements for Resource Formation Service (RFS).
Table 3 Resource types supported by Resource Formation Service (RFS)
Resource Typehttps://support.huaweicloud.cn/usermanual-organizations/org_03_0033.html#section2
URN
privateTemplate
rf:<region>:<account-id>:privateTemplate:<template-name>
stackSet
rf:<region>:<account-id>:stackSet:<stack-set-name>/<stack-set-id>
stack
rf:<region>:<account-id>:stack:<stack-name>
Conditions
Resource Formation Service (RFS) does not support service-specific condition keys in SCPs.
It can only use global condition keys applicable to all services. For details, see Global Condition Keys.
