Updated on 2025-09-10 GMT+08:00
Deleting a DR Drill
Scenarios
If a DR drill is no longer used, you can release the virtual resources by deleting the DR drill from the system. When you delete a DR drill, all the drill servers in it are automatically deleted.
Prerequisites
The DR drill is in the Available, Creation failed, or Deletion failed state.
Procedure
  1. Log in to the management console.
  2. Click Service List and choose Storage > Business Recovery Service.
    The Business Recovery Service page is displayed.
  3. In the pane of the protection group from which a DR drill is to be deleted, click DR Drills.
    The protection group details page is displayed.
  4. On the DR Drills tab, locate the row containing the DR drill to be deleted and click Delete in the Operation column.
    The Delete DR Drill dialog box is displayed.
    If you bind an EIP to a DR drill server, the EIP will be unbound from the DR drill server when you delete the DR drill but will not be deleted. You can bind the EIP to another server.
  5. Click Yes.
