Performing a Failback
Scenarios
After a failover, services are running at the disaster recovery site. You can fail back to your production site with a failback.
Failback is a high-risk operation. After a failback, services are started at the production site. At this time, you must ensure that disaster recovery site services are stopped. Otherwise, services may be conflicted or interrupted and data may be damaged because both sites are providing services.
Failback is not supported for replica pairs whose Type is set to IDC-to-cloud and Scenario set to V2C.
Prerequisites
- Reverse reprotection is completed for all the protected instances in the protection group, and the status of protected instances is Synchronization finished or Failback failed.
- Protected instance services are running at the disaster recovery site.
- All services on disaster recovery site servers are stopped, and all data has been flushed to disks.
Procedure
- Log in to the management console.
- Click Service List and choose Storage > Business Recovery Service.
The Business Recovery Service page is displayed.
- Choose Asynchronous Replication. In the right pane, locate the replica pair housing the protection group you want to perform a failback and click the number in the Protection Groups column.
The Protection Groups tab page is displayed.
- In the navigation tree, choose the target protection group.
The protection group details page is displayed.
- In the upper right corner of the basic information area, click Execute Failback.
The Execute Failback page is displayed.
- Select protected instances and click Submit.
- The protected instance status changes to Executing failback.
- After the protected instance status changes to Failback completed, the operation is successful.
Feedback
Was this page helpful?
Chatbot
