Updated on 2025-09-10 GMT+08:00
Uninstalling a Disaster Recovery Gateway or Proxy Client
Scenarios
You can uninstall the proxy client from servers if you no longer require the BRS service.
Prerequisites
You have deleted protected instances on the BRS console.
Procedure
Linux
Log in to the target server and run the following command to uninstall the gateway or client:
sh /opt/cloud/sdrs/uninstall.sh
If the command output contains the following information, the proxy client has been uninstalled:
Uninstall SDRS successfully.
Windows
  1. Run cmd as the administrator and run the following command:
    C:\cloud\sdrs\uninstall.bat
  2. Enter y to continue the uninstallation if the confirmation information is displayed.
  3. If the command output contains the following information, the proxy client has been uninstalled:
  4. Delete the C:\cloud\sdrs directory.
