Disabling Protection
Scenarios
You can disable protection for all resources in a protection group.
After protection is disabled, data synchronization stops for all protected instances in this group.
Prerequisites
- The protection group contains replication pairs.
- The protection group status is Protecting or Disabling protection failed.
Procedure
- Log in to the management console.
- Click Service List and choose Storage > Business Recovery Service.
The Business Recovery Service page is displayed.
- In the pane of the desired protection group, click Protected Instances.
The protection group details page is displayed.
- In the upper right corner of the page, click Disable Protection.
- In the displayed dialog box, click Yes.
After protection is disabled, data synchronization between the production site and disaster recovery site for all protected instances in the protection group will stop.
Feedback
Was this page helpful?
Chatbot
