Help Center/ Scalable File Service/ User Guide/ Auditing/ Supported SFS Operations
Updated on 2025-09-18 GMT+08:00
Scenarios
Cloud Trace Service (CTS) records operations of SFS resources, facilitating query, audit, and backtracking.
Only SFS Turbo and SFS Capacity-Oriented file systems support recording of resource operations using CTS. General purpose file systems do not support this function.
Prerequisites
You have enabled CTS and the tracker is normal. For details about how to enable CTS, see section Enabling CTS in the Cloud Trace Service Getting Started.
Operations
Table 1 SFS Capacity-Oriented operations traced by CTS
Operation
Resource Type
Trace
Creating a shared file system
sfs
createShare
Modifying a shared file system
sfs
updateShareInfo
Deleting a shared file system
sfs
deleteShare
Adding a share access rule
sfs
addShareACL
Deleting a share access rule
sfs
deleteShareACL
Expanding a shared file system
sfs
extendShare
Shrinking a shared file system
sfs
shrinkShare
Table 2 SFS Turbo operations traced by CTS
Operation
Resource Type
Trace
Creating a file system
sfs_turbo
createShare
Deleting a file system
sfs_turbo
deleteShare
Querying Traces
  1. Log in to the management console.
  2. Click in the upper left corner and select a region and project.
  3. Choose Management & Governance > Cloud Trace Service.
    The Cloud Trace Service page is displayed.
  4. In the navigation pane on the left, choose Trace List.
  5. On the trace list page, set Trace Source, Resource Type, and Search By, and click Query to query the specified traces.
    For details about other operations, see section "Querying Real-Time Traces" in the Cloud Trace Service User Guide.
Disabling or Enabling a Tracker
This section describes how to disable an existing tracker on the CTS console. After the tracker is disabled, the system will stop recording operations, but you can still view existing operation records.
  4. Click Trackers in the left pane.
  5. Click Disable on the right of the tracker information.
  6. Click Yes.
  7. After the tracker is disabled, the available operation changes from Disable to Enable. To enable the tracker again, click Enable and then click Yes. The system will start recording operations again.
