Help Center/ Scalable File Service Turbo/ User Guide/ File System Management/ Expanding Capacity of an SFS Turbo File System
Updated on 2025-09-17 GMT+08:00
Scenarios
You can expand the capacity of a file system if it is insufficient.
Constraints
SFS Turbo file systems support online capacity expansion. During an expansion, mounting the file system may fail. This is because the connection used for mounting may experience an I/O delay about 30 seconds (max. 3 minutes). You are advised to expand capacity during off-peak hours. Note that only In-use file systems can be expanded.
The capacity of an SFS Turbo file system cannot be reduced. You can buy a new file system with a smaller capacity and migrate your data to the new file system.
Expanding the Capacity of a Yearly/Monthly SFS Turbo File System
  1. Log in to the SFS Turbo console.
  2. In the file system list, locate the SFS Turbo file system you want to expand capacity and click Expand Capacity in the Operation column to open the Expand Capacity page.
    Figure 1 Expanding the capacity of a yearly/monthly SFS Turbo file system
    Table 1 Capacity expansion parameters
    Parameter
    Description
    Current Capacity
    Current storage capacity of the file system
    New Capacity
    New storage capacity of the file system
    Constraints:
    • Standard-Enhanced (discontinued), Standard, Performance-Enhanced (discontinued), and Performance: The minimum expansion increment is 100 GB. A Standard or Performance file system can be expanded to up to 32 TB, and a Standard-Enhanced or Performance-Enhanced file system can be expanded to up to 320 TB.
    • 20 MB/s/TiB, 40 MB/s/TiB, 125 MB/s/TiB, 250 MB/s/TiB,500 MB/s/TiB, and 1,000 MB/s/TiB: The expansion increment is 1.2 TB, and the new capacity must be an integer multiple of 1.2 TB and no more than 1 PB.
  3. Enter a new capacity based on service requirements and then click Next.
  4. Confirm the resource information and click Submit.
  5. Complete the payment as instructed and return to the file system list. Click the name of the expanded file system and check that the capacity has been expanded.
Expanding the Capacity of a Pay-per-Use SFS Turbo File System
    Figure 2 Expanding the capacity of a pay-per-use SFS Turbo file system
  3. Enter a new capacity based on service requirements. For detailed parameter descriptions, see Table 1.
  4. Click OK. In the file system list, check that the file system capacity has been expanded.
