Managing SFS Turbo File System Tags
This section describes how to add tags to existing SFS Turbo file systems. You can also add tags when creating file systems. For details, see Creating an SFS Turbo File System.
Tags are used to identify and classify SFS Turbo file systems.
- Tags are composed of key-value pairs.
- A tag key can contain a maximum of 128 characters and cannot be empty. It cannot start or end with spaces or start with _sys_. It can contain letters, digits, spaces, and the following characters: _.:=+-@
- A tag value can contain a maximum of 255 characters and can be left empty. It cannot start or end with spaces. It can contain letters, digits, spaces, and the following characters: _.:=+-@
- You can add a maximum of 20 tags to an SFS Turbo file system.
- Tag keys of the same SFS Turbo file system must be unique.
Procedure
- Log in to the SFS Turbo console.
- In the SFS Turbo file system list, find the file system to which you want to add tags and click its name to go to its details page.
- Click the Tags tab.
Figure 1 Tag information of an SFS Turbo file system
- On the Tags tab, click Edit Tag.
The Edit Tag dialog box is displayed.
- Click Add Tag, enter a tag key and a tag value, and click OK.
- Tag key: This parameter is mandatory.
- Tag value: This parameter is optional.
Return to the tag list. You can see the tag you have just added. You can edit or delete tags.
Feedback
Was this page helpful?
Chatbot
