Updated on 2025-09-19 GMT+08:00
Modifying an Image
Scenarios
After pushing an image, you can modify it, including its type (private by default), category, and description.
Public images can be downloaded by all users.
Private images are controlled by specific permission management. You can grant permissions to allow users to read, edit, or manage private images. For details, see Granting Permissions for a Specific Image.
Procedure
  1. Log in to the SWR console.
  2. In the navigation pane, choose My Images. Then click the name of the target image.
  3. On the details page, click Edit in the upper right corner. In the displayed dialog box, set Sharing Type (Public or Private), Category, and Description, and click OK.
    Figure 1 Editing an image
    Table 1 Editing an image
    Parameter
    Description
    Organization
    The organization that the image belongs to
    Image name
    Type
    The following options are available:
    • Public
    • Private
    NOTE:
    Public images can be pulled and used by all users.
    • If your container engine client and the image repository are in the same region, you can access the image repository through private networks.
    • If your container engine client and the image repository are in different regions, you need to pull images over the Internet.
    Category
    • Application server
    • Linux
    • Arm
    • Framework & Application
    • Database
    • Language
    • Other
    Description
    0 to 30,000 characters are allowed.
