Updated on 2025-09-04 GMT+08:00
Workflow Settings
You can create a workflow to transcode a media file and convert its container format, take snapshots, and extract audio. All tasks in the workflow are executed at the same time, accelerating media processing.
Constraints
A workflow orchestrates at least one task. Repeated task orchestration is not allowed.
Creating a Workflow
  1. Log in to the VOD console.
  2. In the navigation pane, choose Global Settings > Workflows.
  3. Click Create Workflow.
    Figure 1 Creating a workflow
  4. Enter a workflow name.
    It cannot exceed 128 characters.
  5. In the Workflow Orchestration area, create a workflow.
    1. Select a task.
    2. Click in the upper right corner of the selected task to add other tasks. You can also click to delete a task and orchestrate the task again.
      Figure 2 Orchestration
    3. Set task parameters by referring to Table 1.
      Table 1 Task configurations
      Task Name
      Task Parameters
      Description
      Transcoding
      System template or custom template
      If you want to use a custom template group, create a transcoding template first. For details about the restrictions on each transcoding template, see Transcoding Settings.
      Snapshot
      • By interval: The system takes snapshots from the first frame of a video based on the configured interval.
      • At fixed time: The system takes snapshots from a video at configured time points.
      For details, see Snapshot Capturing.
      Audio extraction
      You do not need to set any parameters.
      For details, see Audio Extraction.
  6. Click OK.
    The created workflow is displayed in the workflow list.
  7. Use the workflow to process the audio/video in Audio/Video Management and Audio/Video Upload.
