Updated on 2025-09-19 GMT+08:00
Managing Namespace Tags
Scenarios
A namespace is used to group container images into a category instead of storing them. A namespace is usually created for a project or department of an enterprise. You can add tags for namespaces to facilitate the search and management.
Constraints
Table 1 Maximum number of tags allowed for a single namespace
Item
Quota
Number of tags for a namespace
20
Adding a Tag to a Namespace
  1. Log in to the SWR console. In the upper left corner, switch to your region.
  2. Locate the repository you want to add a namespace tag for and click the repository name. The repository details page is displayed.
  3. In the navigation pane, choose Namespaces. Click in the upper right corner of the page. The namespaces are listed.
  4. Locate the namespace you want to add a tag for and click Manage Tag in the Operation column.
    Figure 1 Namespace management
  5. In the Manage Tag dialog box, click to add a tag.
    Figure 2 Tag management
  6. Enter a tag key and value.
Modifying a Namespace Tag
  2. Locate the repository you want to modify a namespace tag for and click the repository name. The repository details page is displayed.
  4. Locate the namespace you want to modify a tag for and click Manage Tag in the Operation column.
  5. Enter one or more new keys or values.
Deleting a Namespace Tag
  2. Locate the repository whose namespace tag needs to be deleted and click the repository name. The repository details page is displayed.
  4. Locate the namespace whose tag needs to be deleted and click Manage Tag in the Operation column.
  5. Click Delete on the right of the tag.
Querying Namespaces by Tag
  2. Locate the repository you want to query the namespaces of and click the repository name. The repository details page is displayed.
  4. Configure one or more search filters. The search result will be displayed in the list below.
