Help Center/ Object Storage Service/ SDK Reference/ Android/ Quick Start/ Initializing an Instance of ObsClient
Updated on 2024-06-21 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Each time you want to send an HTTP/HTTPS request to OBS, you must create an instance of ObsClient. Sample code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
String ak = System.getenv("ACCESS_KEY_ID");
String sk = System.getenv("SECRET_ACCESS_KEY_ID");
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
// Use the instance to access OBS.
// Close obsClient.
obsClient.close();
For more information, see chapter "Initialization."
For details about logging configuration, see Configuring SDK Logging.
