Help Center/ Object Storage Service/ SDK Reference/ Android/ Bucket Management/ Setting or Obtaining a Bucket Quota
Updated on 2024-06-21 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Setting a Bucket Quota
You can call ObsClient.setBucketQuota to set the bucket quota. Sample code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
String ak = System.getenv("ACCESS_KEY_ID");
String sk = System.getenv("SECRET_ACCESS_KEY_ID");
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
// Set the bucket quota to 100 MB.
BucketQuota quota = new BucketQuota(1024 * 1024 * 100);
obsClient.setBucketQuota("bucketname", quota);
A bucket quota must be a non-negative integer expressed in bytes. The maximum value is 263 - 1.
You can call ObsClient.getBucketQuota to obtain a bucket quota. Sample code is as follows:
BucketQuota quota = obsClient.getBucketQuota("bucketname");
Log.i("GetBucketQuota", "\t" + quota.getBucketQuota());
