Updated on 2024-06-21 GMT+08:00
Obtaining Upload Progresses
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call PutObjectRequest.setProgressListener to configure the data transmission interface to obtain upload progresses. Sample code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
String ak = System.getenv("ACCESS_KEY_ID");
String sk = System.getenv("SECRET_ACCESS_KEY_ID");
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
PutObjectRequest request = new PutObjectRequest("bucketname", "objectname");
request.setFile(new File("localfile")); // localfile indicates the path of the local file to be uploaded. You need to specify the file name.
request.setProgressListener(new ProgressListener() {
       @Override
       public void progressChanged(ProgressStatus status) {
              // Obtain the average upload rate.
              Log.i("PutObject", "AverageSpeed:" + status.getAverageSpeed());
              // Obtain the upload progress in percentage.
              Log.i("PutObject", "TransferPercentage:" + status.getTransferPercentage());
// Refresh the upload progress each time 1 MB data is uploaded.
request.setProgressInterval(1024 * 1024L);
obsClient.putObject(request);
  • You can query the upload progress when uploading an object in streaming, file-based, multipart, appendable, or resumable mode.
  • If the value of ProgressStatus.getTransferPercentage() is -1, the content is uploaded in streaming mode. In this case, you must set the object length (Content-Length) in the object attribute.
