Help Center/
Object Storage Service/
SDK Reference/
BrowserJS/
Object Upload/
Performing a File-Based Upload
Updated on 2024-12-03 GMT+08:00
If you have any questions during the development, post them on the Issues page of GitHub. For details about the API parameters and method, see PUT Object.
File-based upload uses local files as the data source of objects. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.putObject({ Bucket: 'bucketname', Key: 'objectname', SourceFile: document.getElementById('input-file').files[0] }, function (err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
- Use the SourceFile parameter to specify the to-be-uploaded file (a File or Blob object). For example, on an HTML page, use an input tag whose type is file to specify the to-be-uploaded file: <input type="file" id="input-file"/>.
- The SourceFile parameter and the Body parameter cannot be used together.
- The content to be uploaded cannot exceed 5 GB.
- The browser you use must support the window.File feature. Otherwise, files cannot be uploaded properly.
- For details about how to solve the problem, see Unable to Upload Files Using a Browser that Does Not Support window.File.
Parent topic: Object Upload
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
