Managing Object ACLs
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources.
For more information, see ACLs.
An object ACL can be configured in any of the following ways:
- Specify a pre-defined ACL during object upload.
- Call ObsClient.setObjectAcl to specify a pre-defined ACL.
- Call ObsClient.setObjectAcl to specify a user-defined ACL.
Specifying a Pre-defined ACL During Object Upload
Sample code:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.putObject({ Bucket : 'bucketname', Key : 'objectname', Body : 'Hello OBS', // Set the object ACL to public read. ACL : obsClient.enums.AclPublicRead }, function (err, result){ if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
Setting a Pre-defined ACL for an Object
Sample code:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.setObjectAcl({ Bucket : 'bucketname', Key : 'objectname', // Set the object ACL to private read and write. ACL : obsClient.enums.AclPrivate }, function (err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
Setting a User-defined Object ACL
The following code shows how to set a user-defined ACL for an object:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.setObjectAcl({ Bucket : 'bucketname', Key : 'objectname', // Set the object owner. Owner:{'ID':'ownerid'}, Grants:[ // Grant all permissions to a specified user. { Grantee : {Type : 'CanonicalUser',ID : 'userid'}, Permission : obsClient.enums.PermissionFullControl}, // Grant the READ permission to all users. { Grantee: {Type : 'Group', URI : obsClient.enums.GroupAllUsers}, Permission : obsClient.enums.PermissionRead} ] }, function (err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
- Use the Owner parameter to specify the object owner and the Grants parameter to specify information about the authorized users.
- The owner or grantee ID required in the ACL indicates an account ID, which can be viewed on the My Credentials page of OBS Console.
- OBS buckets support the following grantee group:
- All users: ObsClient.enums.GroupAllUsers
Obtaining an Object ACL
You can call ObsClient.getObjectAcl to obtain the ACL of an object. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.getObjectAcl({ Bucket : 'bucketname', Key : 'objectname' }, function (err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); if(result.CommonMsg.Status < 300 && result.InterfaceResult){ console.log('Owner[ID]-->' + result.InterfaceResult.Owner.ID); for(var i in result.InterfaceResult.Grants){ console.log('Grant[' + i + ']:'); console.log('Grantee[ID]-->' + result.InterfaceResult.Grants[i]['Grantee']['ID']); console.log('Grantee[URI]-->' + result.InterfaceResult.Grants[i]['Grantee']['URI']); console.log('Permission-->' + result.InterfaceResult.Grants[i]['Permission']); } } } });
Feedback
Was this page helpful?
Chatbot
