Updated on 2024-12-03 GMT+08:00
SDK Common Result Objects
After you call an API in an instance of the ObsClient class, a common result object will be returned if the exception information parameter is null. The following table lists the object content:
Field
Type
Description
CommonMsg
Object
Common information generated after the API calling is complete, including HTTP status code and error code.
Status
Number
HTTP status code. If the value is smaller than 300, the operation succeeds. Otherwise, the operation fails.
Code
String
Error code on the OBS server. If Status is smaller than 300, the value is null.
Message
String
Error description on the OBS server. If Status is smaller than 300, the value is null.
HostId
String
Requested server ID. If Status is smaller than 300, the value is null.
RequestId
String
Request ID returned by the OBS server
Id2
String
Request ID2 returned by the OBS server
Indicator
String
Detailed error code returned by the OBS server. If Status is smaller than 300, the value is null.
InterfaceResult
Object
Result data generated after the operation is successful. If Status is greater than 300, the value is null.
RequestId
String
Id2
String
Other fields
For details, see the OBS BrowserJS SDK API Reference.
Sample code for processing public result objects:
// Create an instance of ObsClient.
var obsClient = new ObsClient({
    // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
    // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    access_key_id: process.env.AccessKeyID,
    secret_access_key: process.env.SecretAccessKey,
    // Replace the example endpoint with the actual one in your case.
    server: 'https://obs.ap-southeast-1.myhuaweicloud.com'
// Call APIs to perform related operations, for example, downloading an object.
obsClient.getObject({
       Bucket : 'bucketname',
       Key : 'objectname',
}, function (err, result) {
       if(!err){
              if(result.CommonMsg.Status < 300){
                     // Obtain the request ID.
                     console.log('RequestId-->' + result.InterfaceResult.RequestId);
                     // Obtain other parameters.
                     console.log('Content-->' + result.InterfaceResult.Content);
              }else{
                     // Obtain Code and Message.
                     console.log('Code-->' + result.CommonMsg.Code);
                     console.log('Message-->' + result.CommonMsg.Message);
