Updated on 2025-05-12 GMT+08:00
Copying a Part (SDK for Go)
Function
This API copies a part to a specified bucket. This request must contain the multipart upload ID.
After creating a multipart upload, you can specify the upload ID and upload parts for the multipart upload. Alternatively, you can call this API to copy all or part of an uploaded object as a part.
Assume that you copy a source object and save it as part1. If there is already a part1 before the copy, the new part1 will overwrite the existing part1. Then, only the new part1 can be listed and the old part1 is deleted. Therefore, when using this API, ensure that the target part does not exist or is no longer used, to avoid accidental deletion. The source object keeps unchanged in the entire copy process.
Restrictions
  • To copy a part, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • You cannot determine whether a part copy is successful only based on status_code in the HTTP header returned. A 200 response indicates that the server has received the request and starts to process the request. Only when the response body contains ETag, the copy is successful, or the copy fails.
Method
func (obsClient ObsClient) CopyPart(input *CopyPartInput) (output *CopyPartOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
*CopyPartInput
Yes
Explanation:
Input parameters for copying a part. For details, see Table 2.
Table 2 CopyPartInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Target bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
PartNumber
int
Yes
Explanation:
Part number
Value range:
An integer ranging from 1 to 10000
Default value:
None
UploadId
string
Yes
Explanation:
Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8
Value range:
The value must contain 32 characters.
Default value:
None
CopySourceBucket
string
Yes
Explanation:
Source bucket name
Restrictions:
  • A bucket name:
Default value:
None
CopySourceKey
string
Yes
Explanation:
Source object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
Value range:
Default value:
None
CopySourceRangeStart
int64
No
Explanation:
Start position from which a part copy begins
Value range:
A non-negative integer, in bytes
Default value:
0
CopySourceRangeEnd
int64
No
Explanation:
End position at which a part copy ends
Restrictions:
The value must be greater than that of RangeStart. The upper limit of the value is the object length minus 1, in bytes.
Value range:
Default value:
None
SseHeader
SseCHeader
No
Explanation:
Server-side encryption header used for encrypting the target object. For details, see Table 3.
Restrictions:
If the object is encrypted with the key provided by you during the upload, that key must also be provided in the request message when downloading the object.
SourceSseHeader
SseCHeader
No
Explanation:
Server-side decryption header used for decrypting the source object. For details, see Table 3.
Table 3 SseCHeader
Parameter
Type
Mandatory (Yes/No)
Description
Encryption
string
Yes if used as a request parameter
Explanation:
SSE-C used for encrypting objects
Value range:
AES256, indicating objects are encrypted using SSE-C
Default value:
None
Key
string
Explanation:
Key for encrypting the object when SSE-C is used
Restrictions:
The value is a Base64-encoded 256-bit key, for example, K7QkYpBkM5+hca27fsNkUnNVaobncnLht/rCB2o/9Cw=.
Default value:
None
KeyMD5
string
No if used as a request parameter
Explanation:
MD5 value of the key for encrypting objects when SSE-C is used. This value is used to check whether any error occurs during the transmission of the key.
Restrictions:
The value is encrypted by MD5 and then encoded by Base64, for example, 4XvB3tbNTN+tIEVa0/fGaQ==.
Default value:
None
Responses
Table 4 List of returned results
Parameter
Type
Description
output
*CopyPartOutput
type CopyPartOutput struct
Explanation:
Returned results. For details, see Table 5.
err
error
Explanation:
Error messages returned by the API
Table 5 CopyPartOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
ETag
string
Explanation:
Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag value is A when an object is uploaded, but changes to B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the object content, rather than the object metadata. An uploaded or copied object has a unique ETag after being encrypted using MD5.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
Default value:
None
LastModified
time.Time
Explanation:
Time when the last modification was made to the target object
Restrictions:
The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z.
Sample code: time.Now().Add(time.Duration(24) * time.Hour)
Default value:
None
SseHeader
SseCHeader or SseKmsHeader
struct SseCHeader type
type SseKmsHeader struct
Explanation:
Server-side encryption header. If SSE-C is used, see Table 6. If SSE-KMS is used, see Table 7.
PartNumber
int
Explanation:
Part number
Value range:
Default value:
None
Table 6 SseCHeader
Parameter
Type
Mandatory (Yes/No)
Description
Encryption
string
Explanation:
Value range:
Default value:
None
Key
string
Explanation:
Restrictions:
Default value:
None
KeyMD5
string
Explanation:
Restrictions:
Default value:
None
Table 7 SseKmsHeader
Parameter
Type
Mandatory (Yes/No)
Description
Encryption
string
Explanation:
SSE-KMS used for encrypting objects
Value range:
kms, indicating objects are encrypted using SSE-KMS
Default value:
None
Key
string
Explanation:
ID of the KMS master key when SSE-KMS is used
Value range:
Valid value formats are as follows:
  1. regionID:domainID:key/key_id
  2. key_id
In the preceding formats:
Default value:
  • If this parameter is not specified, the default master key will be used.
  • If there is no such a default master key, OBS will create one and use it by default.
Code Example
This example copies parts from one bucket to another.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.CopyPartInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify an object (example/objectname as an example).
    input.Key = "example/objectname"
    // Specify a source bucket (sourcebucketname as an example).
    input.CopySourceBucket = "sourcebucketname"
    // Specify an object to copy (example/sourceobjectname as an example) in the source bucket.
    input.CopySourceKey = "example/sourceobjectname"
    // Specify the number (1 as an example) of the part to upload.
    input.PartNumber = 1
    // Copy the part.
    output, err := obsClient.CopyPart(input)
    if err == nil {
        fmt.Printf("Copy part(bucket:%s, object: %s) successful from bucket:%s's object: %s!\n",
             input.Bucket, input.Key, input.CopySourceBucket, input.CopySourceKey)
        fmt.Printf("ETag:%s, LastModified:%s\n", output.ETag, output.LastModified)
        return
    fmt.Printf("Copy part(bucket:%s, object: %s) fail from bucket:%s's object: %s!\n",
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
