Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Logging (SDK for Node.js)/ Obtaining the Logging Configuration of a Bucket (SDK for Node.js)
Updated on 2025-02-07 GMT+08:00
Function
This API returns the logging configuration of a bucket.
Restrictions
Method
ObsClient.getBucketLogging(params)
Request Parameters
Table 1 BucketRequestInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
Responses
Table 2 Responses
Type
Description
Table 3
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 3.
Table 3 Response
Parameter
Type
Description
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4.
InterfaceResult
Table 5
Explanation:
Results outputted for a successful call. For details, see Table 5.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 4 ICommonMsg
Parameter
Type
Description
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 5 GetBucketLoggingOutput
Parameter
Type
Description
RequestId
string
Explanation:
Agency
string
Explanation:
Name of the IAM agency created by the owner of the target bucket for OBS.
You can select an existing IAM agency or create one. For details about how to create an agency, see Creating an IAM Agency.
LoggingEnabled
LoggingEnabled
Explanation:
Logging configuration information
Table 6 LoggingEnabled
Parameter
Type
Description
TargetBucket
string
Explanation:
Name of the bucket for storing log files.
TargetPrefix
string
Explanation:
Name prefix for log files stored in the target bucket.
TargetGrants
Grant
Explanation:
Permission information list of grantees, which defines grantees and their permissions for log files. For details, see Table 7.
Table 7 Grant
Parameter
Type
Mandatory (Yes/No)
Description
Grantee
Grantee
Yes if used as a request parameter
Explanation:
Grantee information. For details, see Table 8.
Permission
PermissionType
Explanation:
Granted permissions. For details, see Table 11.
Table 8 Grantee
Parameter
Type
Mandatory (Yes/No)
Description
Type
GranteeType
Explanation:
Grantee type. For details, see Table 9.
ID
string
Yes if this parameter is used as a request parameter and Type is set to a user
Explanation:
Account (domain) ID of the grantee.
Name
string
No if used as a request parameter
Explanation:
Account name of the grantee.
URI
GroupUriType
Yes if this parameter is used as a request parameter and Type is set to a group
Explanation:
Authorized user group. For details, see Table 10.
Table 9 GranteeType
Constant
Default Value
Description
GranteeGroup
Group
Grants permissions to user groups.
GranteeUser
CanonicalUser
Grants permissions to individual users.
Table 10 GroupUriType
Constant
Default Value
Description
GroupAllUsers
AllUsers
All users
GroupAuthenticatedUsers
AuthenticatedUsers
Authorized users. This constant is deprecated.
GroupLogDelivery
LogDelivery
Log delivery group. This constant is deprecated.
Table 11 PermissionType
Constant
Default Value
Description
ObsClient.enums.PermissionRead
READ
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
ObsClient.enums.PermissionWrite
WRITE
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
This permission is not applicable to objects.
ObsClient.enums.PermissionReadAcp
READ_ACP
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for their bucket or object by default.
ObsClient.enums.PermissionWriteAcp
WRITE_ACP
A grantee with this permission can update the ACL of a bucket or object.
This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object.
ObsClient.enums.PermissionFullControl
FULL_CONTROL
A grantee with this permission for a bucket has PermissionRead, PermissionWrite, PermissionReadAcp, and PermissionWriteAcp permissions for the bucket.
A grantee with this permission for an object has PermissionRead, PermissionReadAcp, and PermissionWriteAcp permissions for the object.
Code Examples
You can call ObsClient.getBucketLogging to view the logging configuration of a bucket. The following code shows how to obtain the logging configuration of bucket examplebucket:
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function getBucketLogging() {
    try {
        const params = {
            // Specify the bucket name.
            Bucket: "examplebucket",
        // Obtain logging for a bucket.
        const result = await obsClient.getBucketLogging(params);
        if (result.CommonMsg.Status <= 300) {
            console.log("Get bucket(%s)'s logging configuration successful!", params.Bucket);
            console.log("RequestId: %s", result.CommonMsg.RequestId);
            if (result.InterfaceResult.LoggingEnabled) {
                console.log('TargetBucket: %s', result.InterfaceResult.LoggingEnabled.TargetBucket);
                console.log('TargetPrefix: %s', result.InterfaceResult.LoggingEnabled.TargetPrefix);
                for (let i = 0; i < result.InterfaceResult.LoggingEnabled.TargetGrants.length; i++) {
                    const grant = result.InterfaceResult.LoggingEnabled.TargetGrants[0];
                    console.log('Grant[%d]-Type:%s, ID:%s, URI:%s, Permission:%s',
                        i, grant.Grantee.Type, grant.Grantee.ID, grant.Grantee.URI, grant.Permission
            return;
        console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
        console.log("Status: %d", result.CommonMsg.Status);
        console.log("Code: %s", result.CommonMsg.Code);
        console.log("Message: %s", result.CommonMsg.Message);
    } catch (error) {
        console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
        console.log(error);
getBucketLogging();
