Updated on 2025-04-02 GMT+08:00
covar_samp
This function is used to return the sample covariance between two columns of numerical values.
Syntax
covar_samp(col1, col2)
Parameters
Table 1 Parameters
Parameter
Mandatory
Description
col1
Yes
Columns with a data type of numeric. If the values are of any other type, NULL is returned.
col2
Yes
Return Values
The return value is of the DOUBLE type.
Example Code
  • Calculates the sample covariance between the inventory (items) and the price of all offerings. An example command is as follows:
    select covar_samp(items,price) from warehouse;
    The command output is as follows:
    _c0
    1.242355
  • When used with group by, it groups all offerings by warehouse (warehouseId) and returns the sample covariance between the inventory (items) and the price of offerings within each group. An example command is as follows:
    select warehouseId, covar_samp(items,price) from warehourse group by warehouseId;
    warehouseId _c1
    city1    1.03124
    city2    1.03344
    city3    1.33425
