Updated on 2025-04-02 GMT+08:00
lengthb
This function is used to return the length of a specified string in bytes.
Similar function: length. The length function is used to return the length of a string and return a value of the BIGINT type.
Syntax
lengthb(string <str>)
Parameters
Table 1 Parameter
Parameter
Mandatory
Type
Description
str
Yes
STRING
Input string
Return Values
The return value is of the STRING type.
  • If the value of str is not of the STRING, BIGINT, DOUBLE, DECIMAL, or DATETIME type, an error is reported.
  • If the value of str is NULL, NULL is returned.
Example Code
The value 5 is returned.
select lengthb('hello');
The value NULL is returned.
select lengthb(null);
