Updated on 2025-04-02 GMT+08:00
stddev_samp
This function is used to return the sample deviation of a specified column.
Syntax
stddev_samp(col)
Parameters
Table 1 Parameter
Parameter
Mandatory
Description
col
Yes
Columns with a data type of numeric. If the values are of any other type, NULL is returned.
Return Values
The return value is of the DOUBLE type.
Example Code
  • Calculates the sample deviation of all offering inventories (items). An example command is as follows:
    select stddev_samp(items) from warehouse;
    The command output is as follows:
    | _c0        |
    | 1.342355   |
  • When used with group by, it groups all offerings by warehouse (warehouseId) and returns the sample deviation of the offering inventory (items) in the same group. An example command is as follows:
    select warehouseId, stddev_samp(items) from warehourse group by warehouseId;
    | warehouseId| _c1        |
    | city1    | 1.23124   |
    | city2    | 1.23344   |
    | city3    | 1.43425   |
