Help Center/ Cloud Operations Center/ User Guide/ Resilience Center/ Contingency Plans/ Viewing and Cloning a Public Contingency Plan
Updated on 2025-09-17 GMT+08:00
Scenarios
Public contingency plans are predefined plans provided by COC. You can only read and use these plans. The Public Plan page provides basic public contingency plans. You can clone public plans to create public contingency plans.
Viewing Public Contingency Plan Details
  1. Log in to COC.
  2. In the navigation pane, choose Resilience Center > Contingency Plans.
  3. On the displayed page, click the Public Plan tab.
  4. Locate the public contingency plan you want to view and click its name.
  1. Log in to COC.
  4. Locate a public contingency plan and click Clone in the Operation column.
  5. The parameters are the same as those for creating a custom contingency plan. For details, see Creating a Custom Contingency Plan.
  6. Click OK.
    The public contingency plan is cloned.
