Updated on 2025-09-11 GMT+08:00
Viewing a Job Service Ticket
Scenarios
After a job is executed, a service ticket record is generated to record the job execution result. To monitor and record the execution objects and results of the job, you can use the job service ticket function.
Viewing the Execution Records of a Job Service Ticket
  1. Log in to COC.
  2. In the navigation pane, choose Task Management > Execution Records.
  3. Click the Job Tickets tab.
  4. Locate the target ticket and clone or tag the job ticket.
    • Cloning a job ticket: Locate a job ticket, click Clone in the Operation column.
      On the job execution page, execute the job again by referring to Executing a Custom Job.
    • Tagging a job ticket: Locate a job ticket, and modify the tag of the ticket by referring to Managing Jobs Using Tags.
  5. Click the job name.
  6. Perform the following operations based on the service ticket status:
    • Abnormal: Click Forcibly End in the upper right corner to end the service ticket.
    • Executing: Click Forcibly End in the upper right corner to end the service ticket.
    • Paused: Click Forcibly End in the upper right corner to end the service ticket.
