Help Center/ CodeArts Check/ User Guide/ Configuring a Task/ Configuring Advanced Configurations
Updated on 2025-07-31 GMT+08:00
Currently, this function is not available in the AP-Singapore, R-Istanbul, and ME-Riyadh regions.
Configuring the Start Time of New Issues
You can configure the start time of new issues for each task and perform the scanning again after configuration. If the finding time is later than the configured time, the issue is classified as new. If the start time is not configured, gaps between two consecutive check results are considered the number of new issues.
  1. Access CodeArts Check.
  2. Go to the task page. In the task list, click a task name.
  3. On the task details page, choose Settings > Advanced.
  4. In the New Defects Start area, click to configure the start time of the new issues.
    By default, findings since the first successful check are incremental.
Configuring Source File Encoding
You can configure how to encode a file. The source file encoding affects integrity of the source code content identified by the system. The default encoding mode is UTF-8.
  1. In the Source File Encoding area, select an encode format from the drop-down list.
  2. Check whether a message is displayed, indicating that the modification is successful.
